Multi scale gauges are available.
Seems like a chart taped next to the gauge would work with a big red piece of tape at 8,500 psi or so that states, do not exceed this lineā¦
Yes, I realize that max should be 10,000 psi; but I figured a bit of safety margin may have save the list cylinder when two āexperiencedā Makers where trying to smash a penny at max pressureā¦
In my mind, the Automotive purposes for which that press was intended have few cases where it takes over 40 tons of pressure to press out a bearing. I see no reason not to derate the press slightly in hopes that we prevent another blowout at max pressure.
Does anyone see a reason not to try this pressure gauge with the caveat that we install a pressure/ tonnage chart and mark āMax Pressureā in red ink on the gaugeā¦
I was using the press the other day and saw that someone managed to indent into the surface of our nice, non-chinesium press plates.
This is ridiculous. Wonder when it happened.
Maybe trying to press some clam chowder
This dial looks like itās a better fit for usā¦
Front mounted, and from a company Iāve used before, and reasonably pricedā¦
Itās 2.5" wide, but Iām concerned that the fitting will align with the rear hole.
I will take a look this evening when Iām at the space.
http://parkerstore.com.my/product_info.php?manufacturers_id=12&products_id=192
Anyone else know of a better fitting gauge?
we can fabricate a mount if required; we did for the ram. If we can make it fit the original spot all good, but I wouldnāt be worried about appearances if itās a provider that has known good results.
-Jim
Has anyone called the number in the manual to check on the āOEMā part?
800-222-5381
Part TY400001-02a (pressure gauge) Number 57 from the diagram in Ownerās Manual
No need to fab something up if we donāt have to, not to mention we have plenty of other projects if members just need something to do.
Some members treat equipment well no matter what, but others tend to treat āniceā equipment better than equipment that looks like itās straight from Doc Brownās garage.
Iām at work right now, in a cubicle; but I would encourage anyone else to make the callā¦
Thank you all for the support and advice. I shot this using another press without any issues. Link to the video listed below.
Thanks again,
- Cody Eastwood
Cool video.
Love the concept.
Seems like nothing became an uncontrolled dangerous projectile too.
