I have an HP 6459A 0-64V 0-50A DC power supply I will donate if there is interest in it.
It would be perfect for plating, charging, running telecom gear under test… I have no 3ph at home
It is a serious beast of a power supply, capable of continuous duty across the entire range. It does require 3 phase 208, normal light commercial lighting but can be wired for 240 to 380 3ph also.
19" rack mount
DC Output: 0 to 64 V; 0 to 50 A
Constant voltage/constant current operation
Remote programming: remote resistance, or a remote voltage source
Protective Features
Do we have 3 phase power in the electronics room? I’m going out on a limb and saying no. I hate to turn down great equipment but it might not be feasible to use in the electronics room due to the power requirements. If there is another committee that could use it, it would be great, but unfortunately we’re limited to our room at this time.
The E lab does not have 220v 3 phase. There may be 220 3phase somewhere in the shop area. I don’t think the front part of our bldng has any multi phase pwr readily available.
Although I would love for this to be put to good use at DMS and I’m fairly certain the twist lock connector in the show is the correct type if we don’t have a place to put it, and it really does need either a rack home or wheeled cart, then I’ll consider gifting it to the maker with the best use case.
It would be sad to scrap for copper although I bet there is nearly 100 pounds in the 3 phase transformers
I was thinking we would want a large power supply to make some example mechs. So possibly, I’ll talk with Jayson next I see him and see where he sits on the idea. Thanks for keeping us in mind on this.
I’m going to be at the space a couple times the next few weeks so if anybody is interested, speak up soon. I don’t want to put this on the floor but I need to use the wheeled cart I have it sitting on and the cart is at the floor height of the subaru…
