How can I make an elbow? It doesn’t have to be corrugated. OD is nominal half inch.
I don’t think I can reliably make a pie cut bend at this scale - mostly because I’d be cutting it by hand with a hack saw.
The piece is purely cosmetic.
Would square steel tube work?
If round, soft copper tubing, there are plumbing bending kits available with a steel spring which wraps and supports the copper tubing, then slips off once the bend is complete. Here’s a $12 version from WalMart:
Try to find a shorter piece - but it is 1/2"
This is really off the wall, but I have seen large drinking straws at boba tea shops. Maybe you can find a flexible one…
Something like this:
That’s actually the exact size that I need. Given that it’s going to be painted … it would work. I love “off the wall”.
