Last Monday I wondered how accurate the ten day forecasts would be and also how often they are updated. I use Weather Channel, weather.com, for the Addison airport. The shaded numbers are the low for that time and it tends to shift between four days. It’s not perfect but I’m impressed. On Friday, they missed this morning by 20 degrees but the forecast was showing the low temp about right if two days late. That’s what happens when the front speeds up.
Following is an image of my screen with color followed by a text dump.
Weather Channel is an IBM company. While I loved working for IBM, I can assure you that like ALL weather forecasts, it’s voodoo. Nothing more. We can predict the passing of an asteroid that’s spent 4.5 billion years circling in space with FAR better accuracy than we can predict the path of a single thunderstorm across a county.
The asteroid has a limited number of events that might change its path. Not so the weather. I once thought that if we actually collect ALL the events that can change what weather and plug them into a program on the biggest, fastest computer out there, we should be able to accurately predict the weather. Just before it gets here.
That’s not true. it’s an n-body problem and the calculations can get as complex as you want. It just sounds plausible because the average person doesn’t have a framework to apply or assess the asteroid model.
Just wait till we have spaceships. I guarantee the driver will be saying stuff like “navigating under relativistic velocities isn’t as simple as being on planet’s surface. I could predict the exact path of the storm on Jupiter, but nobody knows for sure how many generations it’ll take for us to reach alpha centauri” and people will still believe it.
I wouldn’t call it voodoo. It’s pretty sophisticated and pretty accurate. I wish I knew what other things were going to do 5 days out with 90% accuracy. Say perhaps the stock market?
The process of gathering the data to feed the simulation models is really impressive.
I assume the 90% accuracy stats include/are bolstered by predicting the weather in places like San Diego (let me guess…it’s sunny and warm) or Cochise County, AZ (let me guess…it’s hot and dry?) or Caribou Balls, Nunavut (let me guess…it’s cold and cloudy?) and similar locales.
I only care if they are accurate 90% of the time where I live (because I am selfish and self-centered), and here in Dallas, the weather forecasts suck, especially in regards to predicting rain even within the same day.
