So I’m trying to do a print of some miniatures I found on Thingiverse and I’ve been having some trouble. This was the result of the first attempt:
Got ourselves a collection of quadriplegic space marines here. I was using the lightest support option on the slicer and I believe the issue in the arms is caused by that and it not fully adhering to the supports as it built up. The legs I am pretty sure are my own fault, as I paused the print to check on it at about the cut off point then accidentally missed the resume button for the next 2 hours while I worked elsewhere. Woops.
Anyway I gave it another try this morning with beefier supports. I also decided to raise the models up off the bed 2mm since I don’t like that the feet got sealed to the support bases on the previous print.
All looked well as it was under way, but upon further inspection it looks like one of the legs didn’t complete on any of the models. They look smooshed. I believe this is another support adhesion fail, though the fact it happened with all 3 in the same place gives me pause. Anyone have any ideas for next steps to try? I can just keep throwing spaghetti at the wall but seems like this kind of thing shouldn’t be failing like this regularly
