Is there anyone available within the next week to help get me started with splitting full round pine molding into halves? I figure the table saw with a jig is best but have no clue how to make a jig for this project.
I’ve tried calling a few lumber stores and mounding supply stores in Dallas and no one sells half rounds to the public.
Hot glue the dowel to the bottom edge of the wide side of a 1x4 then rip it on the bandsaw with the 1x4 against the fence. The height of the 1x4 will help hold it straight.
If you want a true half-round you’ll need to place the blade so the whole saw kerf waste comes from the one side of center (glued to the board). You won’t get two full half rounds because the saw will eat some of the width.
The bandsaw blade is thinner than the table saw and you’ll have more control. You can split it 50/50, but you’ll lose perhaps 1/32” (0.035”) from the kerf.
Yes, the bandsaw is much safer for this operation if it comes to it! There are variety of ways you can set it up, but the bandsaw is definitely the way to go.
I’m getting 1-5/16 full round pine moulding and want to split them to reduce the cost. I could use the full rounds in my application if splitting them is too difficult. I know basic woodworking, but have never done anything like this before.
This really goes for anytime you’re using the table saw but especially for making the V-notch. Be very sure not to stand directly behind the blade when making that cut. That loosened up triangular bit can come shooting out of that groove right there at the end. It does it a bit in the video even, but it can become a downright projectile given enough pinching. Stand well to the side and make sure no one’s behind you.
