I’m having trouble sourcing the nuts for this assembly. Any suggestions?
McMaster Carr has everything honestly. They aren’t as expensive as you would think
One of my all-time favorites!
If you can CAD it, you can CAM it.
If you can CAM it, you can build it.
Capt says “It works fine in the 4th dimension”. So you just need to be able to CAM in the 4th dimension…
Those fasteners were used to build this structure:
This should work
