Here is a breakdown on this.
Dimensions:
In the future post how big the piece is suppose to be. You don’t need to have exact measurements but saying it need to be around 8’ long, 2’ wide and 2’ tall helps people figure out how much material they will need to make this as well as let you know where small adjustments in it can save you money on material costs.
Steel:
onlinemetals.com or Metals4U would be the two best local places. Online Metals has a DFW warehouse and Metals4U is 15 minutes from DMS.
I would go with 11ga to 8ga on it, you can use a thicker piece of steel but the weight will go up as well as the cost.
One 4’ x 10’ should be enough to make this but depending on the dimensions you might need a second sheet.
The steel needs to be clean, that means no rust or patina on it. This will make it where it is had to cut and weld the steel. The weathered look will need to be done after the steel has been cut and welded.
Wood:
A lumber supply store will either have a piece of wood in the size that you need or you will need to get some boards and glue them together and them plane them down.
Fabrication:
The CNC plasma cutter can easily cut this out as well as any internal braces and brackets that you will need. To connect the top of the wood bench to the steel base you will need brackets and this can be easily cut out on the plasma cutter.
Once everything has been cut it will be pretty easy to weld everything into place. It is big but thanks to its simple design it can be put on the floor and put into position. Bricks or some discarded brake disks can help hold it in place.
MIG welding will be your best bet. You can tack and weld everything together with it. This includes and braces and brackets that were cut out.
Patina:
This will take a while but it can be done at home. Look up different ways to add a patina to steel, there are products that are made for doing this so I would just buy one and apply it to the steel.
Assembly:
At this point you can put the wood top on the bench and bolt into place.
Moving:
I forgot to add this when I first wrote this. This thing is going to be heavy, weighing over 200 pounds so you are going to want 4 people to move this. I would either have a trailer or a truck that has a full size bed to move this in.
