I’m going to be building a couple of wooden display pedestals, and I need to get two 5’ x 5’ x 1/2" baltic birch plywood sheets to DMS. Unfortunately, neither Lisa nor I have a car we can fit this in. Is there someone in the market for buying baltic birch sheets? I can certainly help with the labor and gas in exchange for piggybacking on your purchase. I’ve also seen that Dakota Hardwoods in Dallas offers free delivery for orders of $300 or more. Anyone interested in putting together a group order for that much? Assuming it’s around $50 per 5’ x 5’ sheet, that’s six sheets. I could certainly use three of them.
Dakota Hardwoods doesn’t seem to carry any 5’ x 5’ Baltic Birch, at least it isn’t on their web site.
Plywood Company of Fort Worth has 12mm (~1/2") for $24/sheet. I’ve been needing to get some 3mm Baltic Birch, myself. I’ve sent them a question about what it would cost to deliver to DMS. I should have an answer within 48 hours. If delivery is too expensive, I can take some time off of work to go pick it up next week.
You might also check Wood World in north Dallas/Richardson. I’m not sure if they have 1/2", but I recently bought a 5x5 sheet of 1/8" baltic birch from there.
@PatrickO, I heard back from Plywood Company of Fort Worth. They quoted out 12 sheets of my 3mm Baltic Birch at $22 each, and 3 sheets of 12mm Baltic Birch at $24 each, and the deliver fee was quoted at $28.54.
Got some 1/4" Baltic birch 5x5 (4 or 5) ply, can’t remember @ central hardwoods in Dallas today for $25 normally 28ish but mine had a bad corner. Dunno about thicker stock.
Baltic birch from Europe is cut at 1525 x 1525 mm, which is just over 60 inches square. Depending on the number of plies, it can be 3, 6, 9 12, or 18 millimeters thick, which is slightly less than 1/8", 1/4", 3/8", 1/2", and 3/4".
These folks… http://www.hlcdallas.com/ …sold me a very fine piece of 18mm by 4 foot by 8 foot Baltic Birch. (Though, I believe the 4 foot by 8 foot was not exactly 4*8 but a close metric size.) My only complaint is that the thickness was consistently a bit shy of 18mm at 17.6 mm.
The 12mm by 5 foot by 5 foot Baltic Birch from the same vendor was a bit rough (lots of patches; warped).
The total, including tax, for the two sheets was $113.12.
Bad phrasing on my part. I’ve only seen the 5x5 offered in Baltic Birch, not the other way around. Really good Baltic Birch (4x8, 3/4 nominal) is about $65/sheet at Central Hardwoods.
