Have Plastics scrap?
A group of folks in the woodshop are working towards permitting the use of plastics on the CNC Router. This has been a much-requested activity. We’re looking for some material to perform testing with, and hoping some generous souls will contribute to the cause.
We’re primarily testing: Acryllic, Polycarbonate, HDPE, and Expanded Poly (Sintra). I think we have a donation for Sintra, but still looking for the others. We’d like the pieces to be reasonably thick, because of the nature of the testing, so half-inch (or greater) stock is the most desirable, though we would probably be grateful for thinner stock as well. The stock needs to be large enough for us to conduct a variety of test cuts, so the bigger the better.
Likewise, if you would like to see a plastic material not listed added to the test, a suitable donation will ensure that your desires are likely met.
The end goal of all this, is a class that will enable you to cut plastics, the addition of suitable tooling to do it, and methodology to protect the Space’s tools and systems. As a bonus, routing the plastic does not release dangerous gases, as might occur on the laser, so it should be a nice addition to the Space.
I’ve got some clear acrylic that I’ll bring in for testing. None of it is 1/2 inch, but I’ll do anything I can to help make this happen.
I have some sheets of plastic and other items of plastic that I would be happy to give up.I don’t know the exact make of the plastic . To me the clear is all what I called plexiglass . I don’t know the difference from polystyrene and acrylic .I have some black plastic that I called Delrin but it might be black nylon . Things like abs ,pvc and ,poly this or that are types I can’t identify at first glance. I have plastic pipe of all kinds that maybe of use to see how it acts to a saw or drill. The pipe and fittings usually have a stamp as to what it is made of so you can use it as an example for that type . Any I have is available to be experimented on . Art Givens and Walter Anderson may be of the most help in coming up samples until next week when I am back. Maybe they can come up with a time and some one to do a look around for what you may be can use. I can give some one an idea where to look if they give me a call.
