@TBJK @Simpl
I’ve been keeping the reading on the refractometer around 10 brix +/- 1. If it’s 11 I don’t cry.
Collin,
It is in a brown plastic case in one of the bottom drawers in the HAAS tool chest. It is cylindrical and about the diameter of an old “d” size battery flashlight and about 6-8 inches long.
Watch some you tube videos on using a refractometer….my sparse instructions will make sense in conjunction with most videos.
- remove the refractometer from its case then remove the black stirring stick from the bottom of the refractometer
- dip the stirring stick into the coolant in the chip trough of the HAAS
- lift the opaque flap of the refractometer on the side opposite to the eyepiece.
- touch the stirring rod to the exposed glass; placing coolant on the glass
- close the opaque flap sandwiching the coolant between the glass and opaque flap
- with the flap oriented upward towards a bright’ish light look through the eyepiece and note where the horizontal line falls related to the graduations
- open the opaque flap
- wipe off the coolant from the underside of the flap and the glass surface with a soft cloth
- wipe off the stirring stick with a paper towel
- return the black stirring stick to its clips on the refractometer
- put the refractometer back in its case
- put the refractometer in the drawer, where you found it
- let the HAAS distribution know what the reading was on talk
@procterc
If this is inline with your normal process please give your nod of approval. If not please let me know the error of my ways. I likely should incorporate a put a few drops on the glass, then wipe it away, then put a few more drops and then measure….just to keep the old residue from contaminating the new measurement.
