HAAS Class Question
Nick - what address to I send my files to. I need to send you the g-code files and and a link to the Fusion 360 file, right?
put the files in your directory on the members drive and send me a message to nicksilva on talk as to where it is.
the f360 file should be exported and stored in the same directory.
It’s at
Members Drive/mike glass/Haas V2
thanks
file fails.
the vertical lead in radius in the pocket must be zero. I harped on this multiple times because it is not in the notes.
Setup 2 facing: no pass extension. should be 3"
I corrected those errors. Hopefully, these files will pass. Same location Members Drive/mike glass/Haas V2
thnaks
file passes.
cheers!
