I tried using kiln #3 this morning. I was able to enter my schedule but when the kiln turned itself on the heating elements didn’t turn on. I turned the kiln off-and-on and when I did it gave me a ‘PF’ error message.
I’ll be by later today and take a look.
I think it may have been unplugged while on and that may have caused the Power Failure code. There are other causes but the first fix is in the manual to hit 1.
Its on now and seemed to run fine. I checked it several times. Other possible option on a PF are broken coil or a short.
Manuals is in the pink folder on the wire shelf.
@PearceDunlap @mrjimmy Kiln 4 is acting up. the alarm beeps when you hit start. We don’t have a manual on this one. I’ll have to googles it. I forgot to put an out of order on it. Might just be something set wrong? I’ll have to do some research. If you are up there please put a sign on it.
