Hello. I need to know if training is required to use the wet glass belt sander. Or can crystal glassware even be used on it?
Hello,
Yes, training is required on all equipment. As soon as the power is installed we will get the classes up.
We ran into several road bumps with the Dept setup that caused a lot of delays. We will soon will have everything worked out. I appreciate your patience.
Thank you,
Anita Willis
GlassWorks Chair
Hi Anita,
Let me know when it is set up. I know how to cut plate and would like to be able to sand some edges. I buy my frames from Goodwill and cut the glass down. Jeff
