Getting Started with 3D Fabrication at Makerspace
Hi there!
I’ve been searching the forums for information on where to start with the 3D fab area. Are classes required to gain access? Are there documents I need to read in order to understand how everything is setup and what permissions I have to use things as a new member?
More than happy to read information via links if there’s already documents available to read.
Thanks in advance!
Hello,
First is a 100 rules class you can take this on learn.dallasmakerspace.org. Once you have this taken you will have access to the computers in the space.
From there if you wish to use the bambu printers we have in person class for those so check the calendar.
The older polly printers have all nline training.
And for Resin check @Keith for training.
Thanks
Great, thanks! I took the rules class and that quiz was tough. Took me a while to answer it. :smiley:
Where should I look for the online training for the older polly printers? I’m assuming it’s these:
https://learn.dallasmakerspace.org/enrol/index.php?id=49
https://learn.dallasmakerspace.org/course/view.php?id=45
https://learn.dallasmakerspace.org/course/view.php?id=44
I’ll hold off on the resin printer stuff till I tackle/learn and start getting familiar with the above.
