Getting an order together
Hello Friends,
I’m getting an order together for REPLACEMENT items that are out along with the lathe mandrels Bob wanted for a class. Please add to this list. Again, this is mostly replacement items and NOT wishlist items. I’ll also be looking at ordering some Carbide end-mills for steel. Just need to figure out how to keep them separate from the HSS ones. I’m ordering at the end of the week. cheers!
Drill bits: 1/16, 13/64, 17/64, 3/8, 27/64
Band Saw Blades
Lathe Mandrels
If you want, you can make your post editable by all comers by turning it into a wiki post.
The upside is that it’ll let people help build the list right there in the first/original post.
There are also downsides, I’m sure I don’t need to lay right out.
If you want to do that:
Click the ellipses
elipses
Then the spanner for “admin tools”
spanner
Then “make wiki”.
make_wiki
This does require trust level sufficient to do so, and/or being an admin/moderator, so if you want it, but can’t do it, team_moderators should be able to assist.
It puts an “edit” button under your post, like so
which others can click to edit the existing post.
thank you but we’ve just done it like this before. I’ll track the posts and make the list.
