How much of a problem to keep your loads balanced on a 240V generator that supplies multiple 120V loads and some 240V loads?
I’m just doing some thinking. I just installed an relatively cheap generator onto an area with loads as above. I am planning to upgrade the generator when I can but now it is 3500 KW and can just drive my 120V loads and 240V well pump x 2. That is, just about everything else that is 240V would likely put it over the rated amperage or wattage.
I have a huge transformer, 30 KW, that I can experiment with and it has some taps that would give me a 2:1 ratio for step up or down. It should be pretty efficient, I’m guessing, as it weighs 350# and the turns are really big copper.
So I got to thinking . . . wouldn’t this balance my loads? See pic below.
- Drive 240V stuff with 240V from the generator
- Drive 120V stuff with 120V from stepped down 240V
- Link the neutrals
- Isolate the loads from the original panel
This arrangement would have to be tapped off the breaker outputs and into separate breakers I guess since driving all 120V loads would involve electrically tying all the 120V hots together whether they came from L1 or L2 of the original house panel.
I have driven all 120V loads with a single 120V generator before by tying together L1 and L2 and it works well. But, of course with L2 and L2 tied together you can’t drive anything that is 240 without isolating it from the panel. (or keep the 240’s on the panel bus and isolate the 120’s)
Aside from the fact that
- The whole thing is not close to any code!
- I would have to double lug some of the circuits (or create an entire separate wiring panel)
- The thing may be impractical in terms of the amount of work, components and wiring
- It would lose some efficiency through the transformer
Does this look like it would work?
Anyone have experience or stories about balancing issues?
