Iâll do my best to answer some of your questions, but it would help if you would give a little context and explain what type of thing youâre trying to cast; object, material, size.
You are talking about the Elegoo Mars Pro resin printer. The training is online at this link and contains the info about print volume, etc. Yes, the printer is working.
Dunno what metal you want to cast, but if you want to do it at DMS we allow casting:
- approximately jewelry-sized objects (< ~2 ounces)
- in bronZe, silver, gold, and platinum
- only from casting grain (i.e., you canât melt down grannyâs silverware)
The training contains this (and much more) info, but it is capable of about 0.002" resolution in X and Y axes (due to the resolution of the LCD array). It can print layers ranging from 0.01mm up to 0.2mm. 0.05mm is the âdefaultâ. Print time is solely dependent upon the number of layers (and the exposure time for each, which is resin-specific).
Having said that, however, there are limitations to the material (i.e., the wax resin). If you tried to print an object and it had some tiny little 0.003" diameter bumps sticking out of it, for example, those would print fine. On the other hand, if you wanted to print a 0.003" diameter spaghetti; the material would fail.
Just because you can print it doesnât mean you can cast it. Normal casting principles apply to whatever you print; especially spacing between features and beveled edges. I can print something finer than I can cast. In fact, right now Iâm struggling with something that has a raised logo and the space between the features keeps filling with bronze - possibly a challenge with the investment but IDK.
This part below isnât printed in wax (but it could be). I printed this as 0.025mm layer height. The word STERLING is clearly legible, if you have great eyes or a telephoto lens. Itâs the size of the date on a penny. However, if I tried to cast this I guarantee that the words would be a solid blob. (I think that if it were recessed (instead of raised) I would have better luck.) The layers are noticeable largely because itâs a large uninterrupted surface. If I were going to cast this part (assuming it had been printed in wax) I would take a sanding stick and sand off the layer lines on the tube and it would be just fine. Remember, youâre also looking at this at about 5x normal size, too.
EDIT: FWIW, I use Fusion 360 for all my designs. The free version has all the features youâd need to model and then 3D print.
