Does the Science department (or any other department) have a means of:
- Pumping down a sealed system to < 10^-3 torr
- Filling the evacuated, sealed system with Neon (I’ll provide the cylinder)
- Monitoring the pressure as the system is being filled up to ~30psig
I guess in terms of equipment, this would include:
- A vacuum pump
- A gas manifold or other gas management subsystem with a regulator
- A pressure sensor (or several) which can monitor from 10^-3 torr to 1.5*10^3 torr
- Anything else that I’ve missed or haven’t considered
If so, great! I definitely would like to continue a discussion of using such a system. If not, is there anywhere I could go to have this procedure performed (AirGas or the like)?
Thanks!
