Fusion laser help
Hello all, took a class with Britton a few weeks ago, but I never got the code to get the key for the fusion laser. Any help appreciated!
@swa …
Remote access to jump server is down so you’re the only person who can confirm.
You can get access if you go to “The Source” and login with your credentials.
After you log in, go to the “Laser” committee - there will be a “Fusion Pro Laser” page that will show you the access code and login information if you have the proper Active Directory Access.
If you don’t see the page [after logging in], it probably means that your Active Directory access is not set up correctly.
Hope this helps.
