Sooo…
I have the plastic circuits out of a keyboard that I’m trying to fix. I have found the broken section of “print”, but I don’t know how to perform the bypass for the break. Conductive glue? Conductive paint? Other?
Thanks!
Wanted to run this up the old flagpole again & see if anyone salutes. I’m thinking this time might be a better time for the knowing eyes than my original timing…
If it’s a crack in the plastic then conductive paint won’t work very well. You can try a piece of mylar tape over the crack and lay some conductive paint over that to complete the circuit.
Which conductive paint do you like?
The appearance of the failure is that the “printed circuit” has rubbed off. Too vigorous on the cleaning, I think, of the spill which was the impetus for the initial disassembly…
Thank you!
I haven’t used enough to have an opinion.
