I was getting everything ready to print on 192.168.200.94 and when I went to extrude filament to remove the remnants from the last print job, it said the printers firmware threw an error (sorry, didn’t get the error) and then said it had to disconnect. The printer reconnects just fine and the temperature controls seem to heat up the bed and the extruder, but when you try to manually extrude filament, it throws the same error and disconnects. Not sure what is going on with it, but wanted to make sure it was reported.
This has been corrected.
