Hello 3D Fab Folks,
I set up to print on .95 tonight and noticed that after extruding through the prior filament to clear through to mine, my filament continued to slowly seep melted through the idle nozzle. I have been having problems getting prints to take (especially early on in the rafting support process). Now I am curious if my filament (Matterhackers Build 1.75mm Grey ABS) is not going to work at 250 degrees. It was cheap filament, so that is the first suspect to me, but there may be a nozzle or heating issue with .95 also or instead. I have not noticed this particular issue with this filament on other printers, but I have also not looked carefully at the nozzle after finishing my initial clearing extrude. What do you think? Any pointers would be appreciated to avoid building more birds’ nests around the nozzles.
