My house was built (~25 years ago) with an ADT security system that, AFAIK, has never been used, i.e. subscribed to via ADT or used for any monitoring (incl original owner). I am not interested in using this system at this time.
Also, there are 4 floodlight receptacles outside, only in my front garden beds (see pic below) which may have had bulbs in them at some point, but have been empty and unused for ~15+ years. I believe they are controlled/activated by the ADT security system, but not 100% sure (since as noted I’ve never had system tuned on). If there is a separate switch for these lights somewhere in the house, I have no idea where it would be; it’s definitely not up by front door area(s), which is only place it would make logical sense.
They are an eyesore and I want to do something with them…either fix them or completely remove.
To fix them, I understand I can check wiring and if OK, replace the receptacle with new ones and put in some appropriate floodlight bulbs. Main question is if I do this, how might I then turn them on without needing to hook-up/power/activate the security system. I’ll call ADT tech support in a bit, but think I’ll be lucky tol get much helpful info from them…
(As a side note, I can’t understand why a security system would only have floodlights in front…If I was breaking in somewhere I’d do it from the alley or back entrances which are typically less observable & sure veiled.)
