TLDR: could this item’s donor pretty-please locate (& donate) its power cord adapter for me?
Recently, someone was kind enough to donate (on the Freebie shelf) an Epson Perfection Scanner (Model 2580). Thank you. This model is very interesting because it has 2400 dpi – which is twice the resolution of my at-home Hewlett Packard All-In-One scanner. More importantly, it can backlight the objects placed on the flatbed, so you can scan 35mm slides and film strip negatives. The software for it looks pretty useful too.
I’d like to use this for my own archiving purposes and then donate/permanently-lend it to the DMS Digital Media department (along with a few old VCRs and related video capture equipment). It seems to me that making digital media from analog media ought to be something you should be able to do in our Digital Media department.
However . . . I couldn’t find the power cord for this little wonder on the Freebie donation shelf. Modern Epson scanners use power cords with a different tip, so they’re not useful. This particular model uses 24V – which isn’t super-common – and takes 1.4A current. The real problem is that the power receptacle on the scanner requires a core pin on the tip that isn’t commonly offered in universal power adapters (or even in uncommon power adapters having an array of various interchangeable tips). Some Amazon listings that purport to be compatible aren’t, and some are intentionally vague about tip designs. I could gamble $25 hoping to get the right power cord, but if you’ve got the original lying around I’d prefer to receive that.
If you’ve got the software disc for running this, that would be useful too.
Thanks in advance!
