Epilogue Laser issues
I have used a set of instructions to create my project! Again I used the same settings and it didn’t cut through. I tried 2 passes as well and still couldn’t make it work! Could any one help me with this
Did you have the cut set in line mode or raster/ fill mode?
I kept it as vector but some are cutting and rest are not
First place to check is the artwork if some lines are cutting and some are not.
Do all of the missing vector lines show correctly when you preview it in the Epilog job manager?
I will check next time when I’m at DMS
