Anyone know what the key code is for the epilogue fusion key box? The code we’ve used for a while doesn’t seem to be working anymore. Thanks,
Colby Sherman
Colby Sherman
A few days ago it was the same as it ever was.
It should be the same as it always has been. If it broke or got changed, I’ll take a look tomorrow.
There are two keylocks on the wall, only one of them is the fusion key.
Yes, I tried both in case it had been switched or I had forgotten which one. Neither seemed to work.
Colby Sherman
Well I will probably be in later today and take a look… Sometimes little door gets a little jammed depending on how the key is put in.
I can confirm what Cody says. It is either locked, or jammed.
Okay this is fixed. The code was actually fine, something in the wheels got a little sticky, so after I rotated it a whole bunch of times and pushed pretty hard on the release, it clicked out. It seems to now be working normally though.
