Engraving cutting board
Hi all, I made a cutting board and want to engrave it. Can someone tell me how I would go about that/what I would need to use? Thanks!
one of the lasers would probably be easiest. In the woodshop itself, the cnc would be the choice although that seems like overkill to me.
Yeah laser is your best bet.
just keep in mind, when you laser cut or otherwise cut into the surface of a cutting board you make a very nice home for bacteria and whatnot. You should also look into filling the engraving with epoxy or similar if you weren’t already planning to do that.
If you are doing something simple like signing it or a small logo we also have a pyrography kit somewhere. In CA last time I saw it.
