I will be at DMS in just a little bit to work on the famed ‘wheel’ that everyone has seen me toting about. The wheel is a 60V brushless and its motor inside is extremely strong/bidirectional/and reversible in that it can be used to generate charge.
The basic problem that I am trying to solve is this: I want control of the motor via Raspberry Pi 3. I have a unit running LabVIEW. I was planning on developing in LabVIEW as this is my environment of choice.
I have option to use DIO pins on RPi, and I also have a PWM board that is IIC available from adafruit. The wheel is interesting because it uses neodymium magnets, and therefore is very strong. It has three wires that feed the delta network of stators, and if you touch two of these wire leads together, it is hard to turn the wheel (thanks Ben for pointing this out).
One problem we are having getting this working is that the wheel is 60V while our microcontroller boards are 3.3 V and the like. We need a level shifting setup to feed the six 60V FET gates, 2 N type FETs per delta connect. Anyone have anything that can easily be modified to do this?
And what is the state of the DMS electronics board mill?
I also plan to bring my Lego Mindstorms EV3 kit up there to model the action of the single wheel autonomous robot. However, the motors for ev3 are too slow and weak. If anyone has a strong motor we can use to build a small rendition of the one-wheeled robot to work on turning strategies, I think we could find a way to patch it in.
If this project interests you, feel free to join me to try and figure it out. I will be in electronics lab soon… Suggestions for this project are welcomed.
