Hi all,
I’ve made an Alexa controlled LED string light controller based on an ESP8266 and some transistors and it mostly works!
based it on an online tutorial somewhere that I can’t find anymore so needing some input from the electronics gurus.
basically I have a 24V source into the board; goes through a pair of capacitors and a 5v regulator to run the ESP8266.
The 24V also runs the LED strings through 4 transistors (RFP30N06LE). One each for Red, Green, Blue, and power (for dimming). The RGB ones work great, and the power one works for about 3 days, before it fails closed (bright / power passing through to full brightness).
What am I missing that’s causing the power transistor to burn out?
Here’s a pic of the board (sorry I don’t have a current one). The pinouts from the ESP run to the left leg of the transistors. The center pins of the transistors run to the LED strip. the right pins run to Ground for the RGB pins and 24V for the power.
