I’ve started listing all sorts of bits and pieces on eBay and I’ve been delighted with the results.
Anywho…you can select DMS as a charity to benefit if you go that route. I did not set this up, I just wanted to share because I just found out.
Yes! Just verifying this is legit. I believe you can select a percentage of your sale to be donated. Thanks for bringing it up.
Just a warning, if I remember correctly it will initially deposit the money to you, and then remove the donation later - though they may have changed that behavior since we’ve looked.
Also, if you use Amazon, you can select DMS to receive donations (or another charity) if you shop with Amazon Smile.
Up to 100% of net (after fees, yada yada yada).
I think this is still the same.
And Kroger
and…Target(?)…I think there might be others, too…
EDIT: @Lampy wonder if we could add buttons to link to these (at least the info about them) under our “Donate” section?
I can handle that tomorrow.
(trying the talk bookmark feature to remind me)
Surprisingly handy!
Thank you!
Was going to get this info setup on the button. Waiting to do a backup of the site first. The WP page editor is kinda borked and gotta have belts & suspenders in place before updating the code
