I’ve used the Dynatorch to cut a variety of thicknesses of steel. Now I have to inter-related questions. Can the torch be used to cut 16 gauge aluminum? If yes, is it possible to cut an aluminum sheet that is perforated with 1/8 inch holes over its entire surface?
Thank in advance for both ye/mo answers and what setting would need to be changed to m both the aluminum and its perforated surfacd.
Maybe I need to do a video on it. There is a physical switch on the plasma. Then there is 2 settings in the software. The check box for lost arc and one for intermittent cuts.
Bob,
You may be unhappy with the finish on the cut surface.
I have cut many sheets of aluminum and steel sheet with 1/8 and 1/4 holes with a circular saw and table saw with a fine toothed carbide saw. Tolerances and finish were perfect. Wear PPE, i.e. leather apron, face shield, cap, long sleeve shirt, ear pro etc. Sharp swarf flies EVERYWHERE at high speed. Be careful at the the start and end of a long cut with a circular saw. The edges tend to flip up if you do not cut straight. Use a guide clamped on top of the work. On a table saw place shim material under the work next to the fence so that the work does not slide under the fence and bind.
Ah, I missed the 10" holes. Still might be doable with a 3" hand held or die grinder with a diamond blade.
I’ve cut small holes in sheet metal (18 ga). I was using the fine cut consumables. They are not consistently round but not terrible. I also had to experiment with the amperage (lower) and kerf shrinking it quite a bit. The recommended settings are not very accurate when cutting fine details like that. I suspect the problem is that the CNC slows down for arcs. So you might play with that parameter also but speeding up will introduce more positioning error.
Your biggest issue will be removing all the slag. That’s going to take a while with the hand grinder if the panel is very large.
Realized he is cutting 10” holes. The metal is already perforated with 1/8” holes.
