I need to make a tank top that has an image and text on it. Rhinestone letters will be applied on top of the dye-sub letters. I’ve only been able to find a suitable style tank that is 50% poly 50% cotton. I just noticed that tag indicates ‘do not iron decoration’…is there any reason that it wouldn’t work as others with this blend haven’t been an issue?
In addition, I’d like the image/text to be all black and I realize it won’t with that blend. Does anyone have an better method that would produce a higher quality result that isn’t dye-sub? I tried to get it printed through zazzle, but since the image is likely under copyright the order ended up getting cancelled. It’s a gift, so not reproducing for $$
This is the test print…
This the actual shirt tag
