On the Donner Laser at 7:20pm, 1/20/24
The X-axis does not move when position the laser on lightburn, only the Y-axis.
Probably an easy fix but dont want to mess anything up
The most immediately easy check whenever this happens is to check the rotary switch. It’s located inside the laser next to the bed at the bottom right corner (sort of below the control panel).
If it’s turned on, it locks the front/back axis on the laser and only lets you move side to side.
