Is there a jig in the shop for cutting pieces to a segmented bowl? I’m dying to spend 100 hours on a simple bowl.
Not that I am aware of…we have an Incra miter gauge that can be set to very fine angle increments, though, so you can make rings of whatever number of segments you prefer fairly easily.
This might be elementary and/or obvious, but if you assemble/glue two halves and then sand the edges flat and parallel, the two halves will fit together with no gaps that might otherwise be caused by slightly incorrect angles on your cuts.
I hope that makes sense.
