Continuing the discussion from Example of parts price gouging…
So, I got my brand-new, shiny starter in last week and finally had some time to install it today. Pretty straightforward, as one only has to move aside the air filter and coolant reservoir (which it is made to do during burping the system).
We begin by looking at the starter to see where we stand:
Hmm, looks like it is in there at an angle. That’s strange, but I guess Toyota knew what they were doing, right? Wait a second … that looks an awful lot like the flywheel teeth through that opening.
Yep, the flange broke off (probably that crunch I heard when I tried to start it). How the hell does that happen?
There’s the missing bit stuck to the transaxle case.
How did that happen? And where is the top bolt?
You can’t see it, but the top starter bolt threads into the starter, while the bottom one goes through a hole and threads into the transaxle case. The threads in the starter side were stripped out smooth.
This starter still functions, but is useless to me as I don’t have the case parts to repair it nor the inclination to try welding it.
I’m guessing that the mechanic stripped the threads out and then, instead of owning up to it, just put the bottom bolt in and thought “that’ll hold”. It did, for about 3 years.
Time for a visit to a shop so they can cut me a check for parts. Irritating.
