Taking @Photomancer’s advice and breaking out each of the Hateful Eight No Go materials into its own thread. Less for me to moderate. Off the top of my head…@pinewoodnut, @talkers, @tomthm, @motopilot, @PearceDunlap, @merissa, @JoshW, @gbeauw, @somecallmery, @bpamplin, @BLOOM, @Kati .
https://dallasmakerspace.org/wiki/Laser_Cutter_Materials
Material: “PolyStyrene Foam”
Danger!: “Catches fire”
Cause/Consequence: “It catches fire, it melts, and only thin pieces cut. This is the #1 material that causes laser fires!!! (Commonly known as Foam Core board) Also known as the white foam that cups and coolers are made of, or the Pink and Blue Sheets found at the hardware store.”
EDIT: Click “like” if original wording is still OK.
