Color temperature as other have explained. 4000K or 5000K are pretty much the standard for workplace lighting. Any warmer (perversely a lower K value) and your eyes have difficulty focusing, any cooler (higher K value) and the blue dominates at the expense of red and yellow color rendering.
If there’s demand for high precision color rendering anywhere in the space, that’s likely best done with task lighting chosen for the specific task at hand.
This is generally true, but not terribly important for how we perceive color.
Here’s a general representation of how various light sources emit by wavelength; specific LED or fluorescent products can vary from the charts below:
The fun thing about noon daylight is that it’s generally in the 5500K range, which under artificial lighting scenarios we perceive to be blue-ish but in the context of the bright sun forcing our pupils to constrict we perceive it as a properly neutral white balance. The atmosphere can greatly alter the color temperature and spectrum composition of sunlight.
While many of us love the comforting warmth of incandescent, its rendition of greens is meh and anything shorter wavelength than cyan is poor despite having near-perfect CRI by definition as a blackbody radiator. There are reasons other than energy efficiency that incandescent lamps are not used in most workplaces.
While there are numerous other ways to get white light from LED (RGB, R+blue-pumped-Green+B, ZnSe, NUV pumped), the dominant topology uses a blue die to pump a yellow phosphor that converts a large fraction of the blue to lower wavelengths, thus the blue spike in its spectrum. The specific combination of blue die and phosphor formulation can greatly alter the color temperature and the CRI / color rendition accuracy of the final product.
Fluorescent is somewhat similar to LED in the sense that uses a pump to drive a white phosphor, however its pump is UV and its phosphor tends to emit in relatively discrete bands. High CRI fluorescent products have nonetheless been a real product for decades.
Some ten plus years ago, LED lighting had such garbage CRI / color rendition that it wasn’t worth publishing (sub-60 was common and the color temperatures were angry blue obscenities north of 7000K). Nowadays even low-end LED lighting products have ~80 CRI; the Hyperikon tubes I linked is 85 CRI. Going any higher for bulk lighting of so much otherwise general-use space probably isn’t worth the markedly greater cost; specific task lighting will solve that need since odds are such work demands more lux than the overhead lights are providing anyway.
