Fuses are on their way, it should be up and running in a couple days
You can laser cut the entire sign from pink/blue insulation foam as @JRyan_Artist has done, then paint with Kilz. The arm could be laser cut in ply. Chain links are cheap.
And as a constructive addition ā¦ I think we need a vinyl sign on the door saying something like āKeep Door Closedā.
I was appalled at the amount of dust that has accumulated on the framing on the outside wall and Iām concerned that it might deal death to the digital denizens inside āthe room formerly known as the annexā.
For not only that but also as a courtesy to folks teaching in the attached classroom.
Iāll take #2ā¦ Will paint and put the flooring downā¦whoo hoo!!
Should we have dust covers for the printers?
That sounds like a good idea. I donnāt know how bad dust is for the computers. That was part of my concern.
Computers already live in the Wood and Metal shops, where there is much more dust than the Room With No Name will hopefully ever see.
Frame update:
Two of the ten are in the annex for your approval. I sanded them and used gesso to harden the paper finish and also added a bit of texture. Then I painted them black using paint from the big squirt jugs in CA. They will probably need another coat (or touch up) and a clear finish, but I stopped after two to make certain the work Iāve done is ok.
The other 8 are in the original place and have been sanded. If you prefer, I can just paint those black without the gesso and texture.
Let me know. --Cindy
Canāt wait to see them. Iāll be up at the space tomorrow after school.
Ok guys the sign is designed: https://drive.google.com/file/d/0B-9lwxsfTaRgMjl2QW1Kd2tCSFk/view?usp=sharing
In my brain the holder is metal of some sort. The sign itself is āstackedā somewhat like the woodshop signs for depth and interest.
Iām emailing @apparently_weird so if you would like to assist with this please chime in and we can get it going.
