Hi. I’m going to try to delegate some of the work on hand to some of our millions of members. We always have a long to-do list and I feel like I haven’t been communicating some of it. Let’s see if this works.
I need someone to man the rebuild/reimagination of the silkscreen cart once the new cart is delivered as discussed here : I would like this cart but it's stupidly expensive - google skills needed
Skills needed: woodworking or metal
Needed by: ASAP
Number of volunteers needed: two possibly three
Budget: Hopefully as cheap as possible - possibly even made from scrap for close to free -
Someone to paint and trim the CA room. I was unable to move the framing pieces at the time I painted (back issues) but we need someone to finish up the job. Paint gallon is in the Annex and additional painting supplies are in the janitors closet. The new “cutout” of the wall to house the darling printer needs flooring put down to look consistent. This is a simple stick and push process - extra flooring is in the annex and a razor to cut it is in the warehouse.
Skills needed: Don’t be sloppy
Needed by: Two weeks
Number of volunteers needed: one -
Someone to help finish out the annex exterior wall with the framing pieces. Dan brought in a cheap board to be screwed into the wall to “skin it” after that we need to affix frame pieces up the wall to as far as we can just like it was done below. Pieces need to be both construction adhesive glued and screwed into the wall - because they will be whole pieces and heavy. One way we could do it is affix the frame pieces on the board on the ground and lift the whole piece up as one.
Skills needed: Woodshop basics, being on a ladder, screwing (hahaha - stupid - I’m like 5)
Needed by: ASAP
Number of volunteers needed: three possibly four -
I have dreams of signs I need built for both the CA room and the Annex. I can sketch them out I want each one to be distinctive to mark our area. I just need a few people to assist in the construction.
Skills needed: CNC and possibly the plasma cutter
Needed by: end of February
Number of volunteers needed: unknown
Sacrifices to the CA volcano: JJ, Adam -
I bought 10 frames to fill with images from around CA - specifically capturing the tools, materials, and spirit of CA. I need high quality images to fill the frames. I also need a team to take apart the thrift store frames and spray paint them so they look a tad more presentable.
Skills needed: Un-framing/matting some framed images, spray painting, photography
Needed by: When the epson is fixed so mid-feb
Number of volunteers needed: two to four-isa
Peoples: JJ, Cindy -
We have a very small tabletop vacuformer. To improve it’s functionality we bought a small heater and envisioned turning it into a small all in one unit. It fell far off the priority list and honestly, I forgot about it a bit. I need someone to facilitate building the unit. I don’t have a sketch but I could sketch it up after I take a look at it again.
Skills needed: basic woodworking
Needed by: ASAP
Number of volunteers needed: one but could be more
Peeps: Mark
