I’m looking to fill an inside-out wood turning with a deep pour resin. The general shape of the resin “cavity” will be like a 3 inch diameter cylinder about 4 inches tall (give or take). Looking for clear glossy result. Can this be poured in a single casting or would I need to do it in layers?
It will have a small wire brush-like Christmas tree in the middle, so good chance for bubbles. Would the vacuum pot be sufficient to pull those bubbles out or should I also cure it in the pressure pot?
