I have this DC motor which has two yellow wires coming out of the base. Along with Red, Blue, and Black. Black connects to the case; Blue is the Motor -, Red is Motor +
See attached image. The inner wheel with cogs spins inside the outer ring. There is a magnetic field present.
Can someone suggest a means to measure the frequency with the arduino? I thought it would be a hall effect sensor, but it does not seem to be the case. As a note, I can measure the frequency with my Extech multimeter. It measures about 2.9khz at full speed. If I reduce the speed of the motor, the frequency reduces likewise. However when I try to measure it with the arduino (pulseIn on pin 2) I get nothing intelligible.
