Do we have a conduit cutter at the space? I’m needing something to cut 3/8" metal conduit without cutting the wire inside, but I will fully remove the wire if I have to.
Flex conduit I take it? That’s easy to cut. Bent it in half. Then pull it apart and use side cutters to cut it. That’s the way I do it.
Yea that is what I will do if we don’t have a conduit cutter
Do not use side cutters. The metal of the flex will damage the cutting edge. (I know lots of people do that anyway.) The cutter on side cutters is designed and hardened for cutting copper wire. I use tin snips when cutting the flex.
Unfortunately I am in Kansas City now, or I would bring my flex cutter by for you to use. You can pick them up pretty cheap.
