CNC Plasma cutter for metal?
Hey, does DMS have a CNC plasma cutter? Looking to cut out some brackets from metal that need to be precise to spec because they will be mounted to a spinning fan motor. Need them perfectly balanced
Yes we do have a CNC Plasma. However I would not be certain that they would be balanced. There still can be some variants in weight.
True for more-or-less every manufacturing technique. Precision balancing happens afterward, exact technique varies, but usually some variation of drilling, though sanding or other material removal might work, too.
