Clausing-Clochester Threads
First what is the standard thread type on the Clausing-Clauster? I need to create 1.998 thread ID to create an aluminum pressure vessel to hold 100 lbs of CO2 pressure. I’m interested in any suggestions. Total volume is about 2.75 cu inches.
The more important question is how many threads per inch? Do you have a valve or plug? You would be able to measure this from whatever you wanted to thread in.
Thanks
Freddy
I’m looking at .25" of vertical thread length. I’m hoping for a pitch that would be 12 to 16 per inch
The machine will do it.
12-16 tpi is easily doable and is quite easy since you will generally move inner to outer direction and shouldn’t hit anything.
