Class time editing?
Is it possible to edit times on classes without canceling and restarting? If so who would be able to change this so I can make time changes.
Generally, the infrastructure team should be the ones to contact.
I don’t know if everybody on the team has access to edit and work with the calendar, but at least a couple do.
This change is possible, with a couple potential caveats that prevent it from happening:
  • If another class is already using the room at the time that you want to extend/ switch to.
  • If it’s honorarium, and the class becomes shorter than is allowed.
  • If the times change drastically and people are already registered for it, we usually will ask that you send out a notice to those people making sure that they are aware.
Thank you I have reached out to there team!
