where do you buy them, and can it do crosscuts? (which is what Iām really after)
Dang good idea Marshall! Gloves or not?
I already own a two-man saw like that: Itās a workout on anything over 20" diameter or so.
Even better plan have people pay you for Cross fit training using a Crosscut saw!
In reality no DMS is not in the business of loaning tools out if you need a 36 inch chain saw your better served buying one yourself.
Woodcraft
Or google for other options
Might be able to find an older at a flea market
Learn sharpening is key to performance of these saws
Genuine question. How long does it take a normal person pair to get through a 40in tree truck with one of those saws?
The only people I had ever seen use those was the āconclaveā team in college. They did the Southern Forestry Conclaveā¦ and I get the feeling they were probably quite a bit quicker than the average person.
See! See!!! Holding the other endā¦uh huh.
I feel vindicated now :ā)
As a woodworker you should know that is the rip saw version
We have been discussing the cross cut model
Two entirely different process, shame on youš
Now I feel anti-vindicated.
This is why I love the space.
I have cut many trees down that were >36" in diameter. Around Texas, only the first 8 feet of the trunk tend to be bigger than 40" in diameter. Here is my process to deal with really big trees after they are on the ground.
A decent chainsaw with a sharp blade makes a world of difference. Stihl, Poulan, etc, with a 20 inch bar. Cut the trunk about 2/3 depth of the bar all the way around. For safety, the trunk may need to be rotated. Another thing to watch for is decay in the middle, which can cause a kickback.
Now that the trunk is cut in, cut the max depth of the bar. This will give you 20 inches towards the middle all the way around. Unless the tree is absolutley massive, a a few standard wedges and sledgehammer will break the pancake off. Iād say anything bigger than 48" in diameter will need bigger equipment.
I had a tree that was 56" in diameter at the base. We made two V cuts to allow the chainsaw to reach far enough in to cut off the pancake. It was an oak tree, so it wasnāt absolutely necessary to obtain every board foot. The pancake was thick enough that I could cut out the half V on either side and still have a 3" pancake.
All that said, its not a requirement to have a 36" bar to cut big trees. If you are doing it for a living, thatās one thing. We are not here, so do what you need to do and get it taken care of.
oh i can get the biscuits out no problem. Itās getting crosscuts (for projects like live edge table) that is easier with a longer blade
While it would be great to have a 36ā chainsaw available on the rare instances where an opportunity like this comes up. I agree itās not in the spirit of the Makerspace to have this as an available tool for external use. We made due as best we could in true Makerspace fashion. And yes, on Sunday the fierce ladies of Makerspace whipped out the handsaw. Itās not for the faint of heart. I ripped a section of my hand open when I tried to help slice a stump in half.
So I get the want for a larger saw bar for a 36" tree. But, a 20" bar can cut sections out of a 36" tree. It just takes multiple cuts and the use of wedges to keep the bar from binding.
Also if your looking for mobile saw milling in Dallas, here is a option:
I have a 36" bar with an Alaskan mill on my big saw. It will cut slabs from about a 30" diameter tree. Iād be hesitant to let anyone without significant chainsaw experience use it, much less rent it. It can go bad real fast on that thing. I could be available this Sunday to help cut it up though. However, if this is the place with the neighbor complaining about chainsaw noise, we might not get much done. Sheās a beast.
the 36" bar makes the larger crosscut milling easier, since I donāt have to line up 2 separate cuts. And the idea is to save money (and have fun) by doing it myself
I have some experience with chainsaws (2 summers on a tree removal crew in Philmont Scout Ranch, plus several years removing limbs with an electric chainsaw for whatever thatās worth).
And I feel that this might have been due to the Superbowl. I was there until almost 8 p.m. on Saturday, and no one said a thing
made this bench with nothing but a chainsaw
