Ceramics Kiln News April 2024
Please follow this thread to determine if your items are ready for pick up. Please pickup your piece(s) ASAP, we are a very busy community and need the room to unload kilns when ready.
If your piece has a star in it, the item is being marked for our 30-day guideline. Please put the stars back in the glass dish on the shelf after collecting your piece(s).
As a reminder there is no personal storage on our shelves or in the Ceramics space, that means bisque items should not be on the In Progress shelves. Please be mindful of other community members and use a ware board that fit the size of your piece, this will allow more room for makers to make.
If you have a piece that’s been “missing”, please double check the Needs Attention thread and shelf. Your piece will have a note attached as to why the kiln team did/can not fire, it is important that you fix the issue in order for your piece to be fired. Continuing to place your item on the shelf for firing without fixing the issue will not result in an ultimate firing of your piece.
If you need assistance or other options to achieve your desired results, please consult the wiki guidelines for firing or reach out to the community for further information.
Thank you!
Needs attention items…
Reminder…DO NOT PUT WET ITEMS ON THE TO BE BISQUED SHELF
Also…these two are all clumped together in bowls…is this how you really want it fired? If not, you need to come in and separate each piece yourself. The team is instructed to fire each item as it is put on the shelf.
Mine is the bottom bowl, that’s how it is supposed to be fired but thank you for checking :+1::+1:.
Glaze came out, looking good!
Please fire them as is. Thanks for making sure! :heart:
Unloaded bisque from new kiln
IMG_8578
IMG_8579
IMG_8580
IMG_8582
IMG_8581
Bisque from 1027 kiln, looked good!
Unloaded glaze, shelves are so so full folks!
Unloaded all the things! Shelves very full! Hurry up and come on down!
Unloaded bisque!
Uploading: 3F8F941C-9F4F-4C8F-ADD9-5A2A1FD4F820.jpeg…
Unloaded glaze!
Added to the Needs attention shelf:
This item was glazed and on the shelf…however it is still greenware. Clay has to be bisqued fired first before going through a glaze firing.
Unloaded bisque:
Unloaded glaze:
New to needs attention shelf today
Unloaded the glaze
IMG_8653
IMG_8652
IMG_8649
IMG_8651
IMG_8648
Unloaded bisque
Steve and I are out of town. Christy will cover for us Monday if there is anything to load.
Unloaded glaze
