Howdy,
I could really use the help of an experienced machinist for re-drilling and threading the holes in my wheel head.
If you’re unfamiliar, a potters wheel has a ~16 in diameter metal wheel. I believe it’s cast, with 3-4 integrated struts. The wheel head itself is only about 1/4" which, but if you drilled through the struts it’s at least 1 1/4" thick. From the factory, there are two holes drilled through the wheel head and struts that are threaded to receive two machinist screws, which are used to secure attachments called bats. My issue is that the holes in my wheelhead are ever so slightly off center, so my bats rotate wonky when the wheel is turned on.
I could really use some help precisely redrilling and threading two holes in my home wheel. Two holes need to be precisely 90° and exactly equidistant from the center. I can take the wheel off and bring it to DMS, but I don’t have the expertise or confidence to undergo this project myself. It would really be amazing if I could get some help with this.
