Can I pause my membership
If I discontinue my membership and sign up again after 3ish months, will that mean that ill have to do all the training all over again ?
No you will not need to retake any training as long as you use the same login information
One thing you might need to be aware of is if you have a personal storage bin. The $20 is one time as long as you remain a member. I’m not sure how frequently purges happen these days but it could happen. There is a small possibility that if you are inactive long enough items in your bin will first go to purgatory and then be discarded as abandoned if you are away long enough. So I’d recommend emptying that box first before an extended pause.
Sounds good. Thanks
I am guessing when I go to the portal to cancel, I should select end of billing cycle (there are two options, the other option is immediate). My billing cycle for the new month starts 24th November.
Yes, choose end of billing cycle.
One other thing to consider is that if the membership rate changes, or is currently different than what you are paying, then you will get reinstated at the newest rate.
